Navin Talati
- Joined
- Oct 23, 2006
- Messages
- 124
- Points
- 101
Friends,
My car is Linea T-Jet 1.4 L Emotion model (F.L.India 2014).
Unfortunately my linea T-Jet submerged into the flood water up to the dashboard's lower level. I am trying to revive it. after complete drying it started and mostly gives all equipment and instruments working response. I found mainly TWO faults:
1. The battery is not getting charged. While engine ON, the terminals at battery must show about 14.5 V. But it shows just that of the battery (12.3 V or whatever it has remain) So I am unable to drive it. After starting the engine it must remain ON if I detach a negative terminal of the battery. But the engine gets OFF. Continuity of the connection from alternator to battery is ok. So I suspect the ALTERNATOR and I must repair or replace the same.
2. The A.C. blower fan is also jammed and hence must repair or replace.
So what I need as guidance are:
(A). How to replace the ALTERNATOR. For that how should I proceed in the procedure. for this should I have to remove the drive-shaft / axle?
(B). How to check and repair the Alternator.
(C). I could remove the A.C. blower fan but how to repair it?
(D). What other precautions and checks I need take while repairing.
(F). Electrical Circuits for ABS and AIR-BAG for the Linea T-Jet 1.4 L Emotion is also requested as it shows the error.
Regards to all in anticipation.
Navin Talati / 01-08-2018
