General  alloy wheels question??
cozzie2002
Kingston Upon Hull
hey had a post up other day bout some alloys well i have ordered them. My punto is apparently 4*98 (am i right?) and the wheels i have ordered are 4*100. got them from rochfordtyres (got the discount too thanks dave ;)) they told me to get these special bolts so ordered them too:
http://www.rochfordtyres.co.uk/prod...=cat&strKeywords=&strSearchCriteria=&PT_ID=71
will these fit ok wiv no movement etc jus bit concerned thats all as dnt no much bout fitting alloys...
thanks for any help!
Mike
i am useing wobbly bolts and thay are fine also ma mate is use them it will not move the little washer only moves to give you a couple of mm so thay will fit if you still have your steal wheels on there ma be two little pins/spoke holdinf the wheel on you need to take these off thay come off easy its whern you take the bolts off then the wheel you will see them better.thanks.michael
