Styling Alfa 147 interior?
The door cards are side trims will almost certainly be different as the 147 has more in common with 156 than Punto. But seats will fit. Try google ("punto 147 interior") it finds more for me than FF's own search.
mate im pretty sure that punto 3 door and 5 door rear seats have the exact same fitments....the brackets are same and seat suze are same 3 door seats should fit mate
to fit rear seats you have to remove and trim the latch housing and and unbolt the latch pins to move them fowards slightly then tighten them again...need to do both perfect otherwise the parcel shelf wont fit int without been bent against the boot lid when closed lol
the bottoms of the seast need welding im just goign to wled the original brackets to the seats but at an angel if you know what i mean :)
Usually its 147 3 door seats going into a 3 door Punto. But 147 and 156 use the same seats, so 156 fronts would be fine in a 5 door Punto. The backs who can say(?) the 156 doesn't have folding seats so may need to brackets etc making up from the old Punto seat.
Those on ebay look well cool :)
hello so the 3 door 147 interior fits ok but what about a 147 5 door will that fit the same in a 3 door mk 2? thank you
