- Joined
- Jul 1, 2012
- Messages
- 422
- Points
- 224
I bought an Alfa 145 1.8 T-Spark last weekend....and the day after, it developed an oil pressure issue.
Just wondering if anybody has any experience with these engines.
It drove the 300 miles home no problem. The next day, drove 30 miles, parked up for a couple of hours, came back, started the engine, and the oil pressure light was on. Checked oil level, all fine. Started again, light still on, and after about 10 seconds, top end started to become noisier. At that point I turned off engine and called the AA.
To cut a long story short, my mechanic has taken the sump off, and the oil pickup in the sump is fine....the sump in general is very clean.
So....he's going to run a pressure test on the pump, and see if its working or not.
The pump has a sprung sliding pressure valve built in. According to the manual, if this gets stuck open, it vents straight back to the sump.
It seems its a common problem with the 2.0.....but the 1.8 has a very slightly different oil pump....externally identical....so possibly something slightly different inside? I've bought a 2.0 oil pump off Ebay for £10....so I was hoping to swap the spring and piston over.
Has anybody had any experience of this before? Is it possible just to replace the valve? The pump is £250 from Alfa.....
