Technical Alarm central locking.....
LanciaMad
Prominent member
Toon
Fitted an alarm to my sei today, everything works bar the central locking bit. I read the bit on the FAQ bit but Ive done everything right as far as i can see. There are only two wires I have connected to with the alarm loom. In the instructions there are loads of different types of central locking some using only two wires others using up to six! Anyone help me?
scottc1088
Established member
chesterfield
CDL Lock Wire:​
BLUE/WHITE
CDL Unlock Wire:​
WHITE/RED
CDL Pulse Type:​
NEGATIVE
CDL Location:​
LOCATED IN HARNESS TO DRIVERS
DOOR
just match this up to wires on your alarm system
OP
OP
LanciaMad
LanciaMad
Prominent member
Toon
Hang on, think I may be beintg a bit daft, is it common for an alarm to come with the central locking bit de activated, I might have to activate that function...
custard
Status: DEFCON Grumpy
Edinburgh
wouldnt think so as its just a pulse sent from the alarm brain
edit:if this is for a cinq you MUST connect it to both drivers and paasengers wires as shown in the faq
Nottingham
You need to check if the alarm gives a positive or negative pulse. ie: +12v or 0v. You need a 0v pulse.
where the bloody hell is
and how would u suggest this is done? as there are 2 wires coming from the alarm, so how are u supposed to connect them to wires in the drivers loom and the passengers loom? :confused:
OP
OP
LanciaMad
LanciaMad
Prominent member
Toon
Sorted it guys, the cobra specific instructions for the seicento were slightly different to what they should have been.
Two extra wires from the alarm loom needed to be earthed. Wonder if the central locking is slightly different between the spi and mpi? nevermind, now sorted. Lock goes up, lock goes down. Lock goes up, lock goes down. Lock goes up, lock goes down. :D
custard
Edinburgh
that will be 4 then ;)
even if it didnt the CL is split via the 2 sides so you could just cut into the 2 wires to extend to do the other side
OP
OP
LanciaMad
LanciaMad
Prominent member
Toon
that will be 4 then
I only had to connect to one sides lock and un lock, the other two went to earth. If you push one side down the other side goes down automatically, hence central locking.
