General  Aircon Fault ??????????? HELP
Wolverhampton
While out yesterday, this appeared on the display 'AIRCON FAULT' my climate control ceased and also the outside temp now only shows 2 (--) dashes.
Can anyone suggest what might be going on? How to fix it please?
Note: if you use the fan switch (1 - 2 - 3 - 4 ) all work ok but the 'AUTO' won't.
George
02 1.6 ELX
Check that all the connexions to the drivers door mirror are good as the temperature sensor ( thermistor ) is the little button like object protruding from the bottom of the mirror. These rarely fail ( although they go open circuit if they do ) but the connexions have been known to go high resistance so a clean of all contacts may sort out your problem.
Good luck
Peat
Re: Aircon Fault. HELP
Check that all the connexions to the drivers door mirror are good as the temperature sensor (thermistor) is the little button like object protruding from the bottom of the mirror. These rarely fail (although they go open circuit if they do) but the connexions have been known to go high resistance so a clean of all contacts may sort out your problem.
Good luck
Peat
Thanks Peat, I'll try that.
Thinking about it, I changed the drivers door mirror at about the same time, so there could be a connection (or lack of one haha)
George
T14086 - give that man beer!
The mirror I had put on was a 7 pin connector (mine are 9) so strange things were happening with the mirror movement :eek:. I never noticed the climate control until later and didn't add 2 and 2 together properly, shoulda come out 5 sholdn't it :D
Put the old mirror back on today and all is ok again. :)
Thanks to PEAT and T14086, cheers (y)
