Technical Airbag system wiring diagram
Steph3071
Can anyone tell me where I can find a wiring diagram for a 2011 Punto 1.2.
I found one at car4data with the id 199002892 - E7030 AIR BAG but it doesn't appear to be correct.
The diagram I found appears to have two 24 pin connectors to the Airbag ECU. Mine has a 24 pin and a 32 pin.
I also note that my car does not have a passenger seat occupancy detection switch, there is no switch in the passenger seatbelt buckle (no idea how id decides the passenger airbags are required) and no crash sensor behind the front bumper. (Discovered after removing the front end so I could do a continuity test on the non existent wiring!)
I have steering wheel and passenger airbag, as well as curtain airbags in my system.
Model
1.2
2011
Hello,
You have probably the pre 2008 diagram, it has smaller connectors as I can see.
You should look for the post 10/2008 diagram which has more than 24 pins on one of the connectors:
I got it from eLearn.
