Technical Fuse box wires diagram
PuntoEvoCam
Cheltenham
hi I’m struggling to find the actual wiring diagram for the fuse box for the tjet and Evo. As I’m needing to wire a tjet fuse box to Evo wires. So if anyone has the diagrams for the two would be appreciated 👍🏼
Model
Tjet
Hi Guys,
Are the scant wiring diagrams in the Haynes manual correct ??
Poor diagrams with insufficient info at best.....
Hence the monica " haynes book of lies ".......
I love the caviat " typical wiring diagram" they often use .......an exact diagram is needed to be of use, to stop sparks etc.......
Found some info on punto fuse and relay boxes on google, about to print info off and compare with actual car......please god.....
Still hunting for exact punto wiring diagram...
using real computer again today in public library....managed to get into e learn, discovered earth points info and printed off.
fuse and relay info next i hope, then headlights wiring, especially steering columb switch unit.
Haynes diagram show columb wiring feeds computer unit that then controls relays for headlights etc..
Anyone know if the columb switch unit has "on board logic" and feed info to computer via rs232 or a similar coded info please ?????
