had far to many problems with a fiat stilo 5-6 months ago we had the good old throttle actuator problem sent of for testing and got send back a ok
checked all the norm ect, ect, ect
turned out to be the ecu sending incorrect voltage/current to the 3rd bank on the actuator replaced ecu an so i am here again lol
this time car was brought to me with a misfire so investigated and found that unplugging coil plugs 1 an 4 reading left 2 right made no difference what so ever so jumped to the presumption that coils were down as are well known for going in pairs
2 new coils £113 none genuine article (all the same to me lol
all fitted misfire still there so curious at this stage swaped 2-3 coils with old ones and yet again car was running on 2 not good
got usb odbII lead and fiatecuscan installed and changed relevent settings everything fine an connected first time
cleared errors disconnected and then when i went to start the engine got these errors (airbag failure, loose connection,security failure and something bout watter temp) and nothing when i turned the key as if to start car
the air bag warrning light is permantly on and is the only light on dash and because what ever is stopping car from starting it is also stopping me from connecting to the diag program
so far i have tried unplug batt for hour no change
i tried unlock an lock from remote as to reset imob still same
disabled pass airbag (with key)same again
sat here for like 3 hours reading old post some seem the same but i have air bag not asr?? failure like other post i saw with the exact same other symptoms that 1 started from a misfire but only on 4 unlike 1 and 4
run out of light so thought i would post and see if you very helpful people could list the things that i should try in your opinions in the order you would advise also any details at to when i test 02 and lambada sensor loom plug and sensor voltage/resistance injectors output from loom and coil outputs from loom and maybe injection and coil plug numbers diagram
i plan on testing
1st injectors
2nd cleaning d4 connectors
3rd double checking all fuses
4th ecu earth
and pending info posted
! injection plug loom voltage
! 02 plug loom voltage
! lambda sensor plug loom voltage
also i need to reset the airbag ecu??? as i understand it by modding the usb wire as in the guide of memory pins 1-3 need connecting by wire has any 1 tryed and how reliable is it as it not my car its me grandads an dont want 2 naff it up
i thank you for any reply / assistance
so it really dose mean
F ix
I t
A gain
T omorrow
lol
i plan on testing
1st injectors
4th ecu earth
F ix
I t
A gain
T omorrow
lol
