airbag isolation switch - glovebox
if it said short circuit then you could test this by disconnection of the switch:)
ta,
basically If I turn the switch to OFF , then I can clear the fault code,
turned back on fault is there + cannot be cleared, :(
BUT apparently driving it this week in OFF position the light flickers on + off randomly.., so may well be a dodgy connection,
think I'll get a punto switch from a yard tomorrow ;)
then see what happens in all the scenario's,
Charlie
OK,
Punto switch now fitted,
electrically perfect, plug + play.., both airbag lights now OFF
However, the 00'ish punto key profile is different from the panda '04,
so I cannot de-select the passenger airbag,
it does look as if I can change the "lock" part of the switch by dis-assembly..,
thanks for your help,
Charlie
