General  Air Vent Problem
russco1932
Perth
I have a Fiat Ducato 2006 Motor Home. The inside/outside Air Vent control lever works perfect up to around 60km/h.
As the speed increases up to 100km/h, the "air control lever" has difficulty staying in the "Inside Air" position.
It appears the outside air pressure is exerting too much pressure on the vent flap.
The local Fiat Service Centre is unable to fix the problem.
Any suggestions?
There's no way for owners to make adjustments. Initially the agent removed some leaves and said that was the cause, but the problem was still there. He claims he contacted Fiat with no success.
I'm curious to know if other owners have the same problem.
