Technical  Air Conditioning
Raggermuffin
Is Air conditioning standard or an extra on Fiat Doblo 1.9 Multijet Family 5dr?
Merci!
Yes - Looking for either a Fiat Doblo or Fiat Qubo. Must have Air conditioning Diesel and under 50,000 miles. My budget is rather measly of £4000 but better than what would be offered in Part Exchange.
For the age of Doblo I have, 2007 1.9 jtd 105bhp, the 'Dynamic' model has aircon. and the 'Active' doesn't as standard. I think 'Family' is separate to those.
I had a quick look on AutoTrader (UK), the Family models I saw did NOT have air conditioning listed. Perhaps you can try a more detailed search yourself. http://www.autotrader.co.uk/
If you are in France (as the flag suggests), your local options may be different.
Hope this helps a bit, and best of luck with your search.
Barry.
I have the family model (2007) and it has A/C, I think on the newer Family models it is an option though.
Merci!
I have a Doblo 2007 1.9multijet 120bhp Dynamic, it has aircon, but it only holds charge for about a week.......I open the window now, its uses less fuel
You obviously have the WD40 A/C version then?
My 2007 1.9mult.'s air con failed when it was 7 the condense radiator is at the front of the car behind the grill in front of the eng. rad. It's made of alloy hence it went to powder and leaked. It cost £70 to buy I had to remove the bumper which took an hour then £35 to have it re gassed. The van is 9 now and cool as you like
