NoahR
Hi all,
Just bought a 2007 Fiat Ducato H/R MJ 120 2.3L (Not sure if there's other specific info needed?), and the air con doesn't work. The previous owner had it regassed a couple of years ago, and said it held pressure fine, but didn't work. - The light comes on, but the compressor doesn't kick in, and it doesn't blow cold.
I've powered the compressor directly with 12v from the battery, and the clutch kicks in. I've also checked the two fuses (both fine). I'm going to order a back probing set so I can back probe the three wires going into the pressure switch and read their voltage. I don't have any sort of scan tool for the vehicle, so I can't read pressures. I also can't work out where the relay is to check that. I expect it's an issue with the pressure switch, but I would like to be sure before I pay a garage to sort that.
Does anyone have any other suggestions on how to proceed?
Thank you
Noah
Thank you
Noah
- Fuel Type
- Diesel
- Year
- 2006
