Technical  Diesel Dipped headlight not working
Nick5161
Warwick
2019 Fiat Ducato 130 Campervan
Currently halfway up a mountain in Switzerland. N/S dipped headlight is not working.
Bulb replaced and checked - ok
Fuse replaced and checked - ok
No power to plug to bulb.
Is there a relay that I need to check?
Any other suggestions?
My vehicle knowledge is limited and I think I’m nearing that limit.
Many thanks.
Fuel Type
Diesel
Model
Autoquest CV20
Year
2019
Mileage
24000
In the earlier Euro 4 models each dipped beam is fused separately in the cab fuse box. F13 is L, F12 is R.
I am not sure what the fuse allocation is in later euro5/6 but presume the circuity is similar.
  • dipped headlights.pdf
Many thanks. I’ve checked and changed F12 & F13. Still no joy.
The circuit I posted shows the output of the relay feeds both fuses so the common feed must be there as one side is working. Guess you need to check the voltage at F13. PS. I have checked later X290 model fuse allocation and F13/12 are still the dipped beam fuses. I do not have a circuit so cannot confirm that there is still a single relay with a common feed to the two fuses.
