seicento-racer
Hi I have a Schumacer Sporting seicento MPI 51reg I have two problems the fan wont come on when it gets hot, I have checked all the usual places fuses relays etc, I know the fan is OK I have had to replace it, I have checked the voltage at the thermostat housing which had 4.9 volts, the temp high light comes on just before she boils over, I was told the ECU tells the fan to come on Via this temp sender in the therm housing, is that right? has anyone else had this problem. also whilst fiddling with all the wires and relays the airbag light has come on, I have tried taking the fuse out, but even then the light stays on, plus its due for test in the next couple of weeks, any ideas ??
Cheers Roger
Cheers Roger
