Hi Dan (I guess),
I would source an antenna connector from the local electronic shop, cut the cable at the old connector and solder or crimp (depending on type) the new one on... No need to pull the entire cable from the antenna ...
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
