General Adjusting headlights
applemella
Northamptonshire
Have tried adjusting my headlights using the up and down arrows on right hand side of dashboard-this has no effect.
Can the lights be altered manually?
As unable to adjust using buttons any ideas what the fault might be.
Thanks for reading
Thanks for reading
Yes they can be adjusted manually.
The electric motors that adjust your headlights are faulty and need replacing.
Try using the search feature on the site. Check this out.
https://www.fiatforum.com/stilo/62363-headlight-alignment-motor.html
There are two white plastic screw shafts on the back of each headlamp. One adjusts the beam horizontally and the other vertically.
You need to be very careful with them, they are likely to be siezed and could snap off.
