Technical  Adjust biting point
imranbashir
I was just wondering if it's possible to adjust the biting point from the clutch pedal side?
I had the gearbox repaired and got the clutch changed at the same time and the bite point is quite high.
I know its hydraulic but something has to push on the master cylinder, and was wondering if there is some adjustment there.
Don't have specific knowledge on your model, but generally modern hydraulic clutches are self adjusting and trying to adjust or change anything around the pedal area etc. is ill advised, as in don't do it!
Normally if you have a new clutch fitted it will start to "bite" nearer to the floor as you bring the pedal up when compared with an old/worn one which usually doesn't start to grip and transmit drive until the pedal is almost released.
If it feels wrong to you as the regular driver of that vehicle, I would say speak to you garage/mechanic about it.
