I have this error P1442 is this the pump that’s faulty? Im also getting risk of filter blocking warning which eventually puts fan on, last time this happened van stopped.
I also took tank off and it has pat fluid lots so its not that.
Thxs for advice
2012 scudo 1.6 hdi van
Not sure if relevant , but on a 2012 Citroen C3 Picasso that used basically that same engine, the Eloys Fluid tank just before the N/S/R wheel even if fluid level topped up they needed to be bled using a diagnostic tool to get the air out to work and the pumps were known to fail also.
Fairly sure the alloy 1560cc? engine in the Scudo is the Peugeot/Citroen based one.
There may be more information on the Peugeot or Citroen Forums relating to this.
Just read your error code online and found this if relevant. :-
"After the fuel cooling tank needed replacing ( ploughing through deep puddle at high speed), my local garage replaced that, all was good.
But, on refilling my almost empty fuel tank, the 'Risk of Filter Clogging' appeared on the dash; with the warning triangle of death too...so, back to the garage who found this P1442 error code with "additive system low or adding impossible"
Took it to Citroen dealer following week as advised, diagnosed again (kerchang..£125 please) which resulted 'additive fuel pump fault out circuit, checked wiring and power supply all ok, recommend to replace pump/tank.'
the cost i'm quoted from Citroen is £672 (yikes
I didn't get a detailed read out from the dealers (shame, I realised too late) but after doing the 2500 rpm trick on the last journey I made, the warnings no longer appear."
