Technical  AC pre-filter
Munich
Hi everyone,
I wanted to share a recent project on my Panda and get your thoughts.
A smelly AC led me to disinfect the system and change the cabin filter a bit ahead of schedule (only 6 months in). While I expected some dark dust, I was surprised by the amount of physical debris—leaves, bugs, and fluff—that made it all the way into the housing, despite the car being mostly garaged.
To protect the AC ducts and evaporator from future debris, I looked at the main air intake under the scuttle panel and 3D printed a custom pre-filter.
So far, it hasn't restricted the cabin airflow. The mesh is coarse enough that it shouldn't clog up instantly or block circulation. I know I’ll need to clean this pre-filter periodically, I think it will be much easier and safer than trying to vacuum inside the tight cabin filter housing (and risking damage to the evaporator).
What do you guys think? (Please ignore the bad print quality)
You could (if you wanted to) share the files as other people might want to do the same
Here's the printables link:
I tried to find the part number, and tried to check if it might fit older 319 Pandas, but I fear that older models have a different intake grill.
If anyone in the forum wants to print it and needs advice please let me know. I added disclaimers to the printables page tho because I'm not sure yet how this pre-filter will perform. I think it might need periodical cleaning to prevent clogging/straining the hvac blowers.
