Technical AC Not working Code 0530
LorenzovD
Hello,
Recently I bought my very own Fiat Stilo 1.6 Active
plus from 2004.
The car is in a pretty good shape, the only thing that is not working is my AC. I got my own OBD scanner and I got the p0530 code.
P0530 - Pressure Sensor AC flued "A" circuit.
Does anyone know what the problem could be? Does this mean the sensor is bad or is there an other common problem that causes this to happend?
- I checked fuse f19 and this one is still functioning properly.
I hope someone can help me with this problem. Thank you in advance!
Lorenzo
You can try reconnecting the sensor, or changing it. Also try sticking a screwdriwer into high pressure valve to check if there is any pressure.
