Hi again,
2008 1.2 sport
I brought the car in to a garage to have varies bits of work done, before this I never had the ABS light come on. Drive away from the garage and the ABS light came on.
Now, when I turn the ignition on and the dashboard lights settle down, the ABS light does not stay on, it turns off. Start the engine, still off. Pull off and it seems that as soon as I hit around 30mph, the ABS light comes on and stays on for the remainder of the journey. When I turn the car off and back on, ABS light goes off, rinse and repeat.
One of the jobs that was done at the garage was a handbrake cable replacement. After a bit of research, I'm guessing that while they were doing this, some dirt/rust has got onto the ABS sensor and is causing the issue? Does this sound about right? If so, where can I locate the sensor? If not, what would be the next guess?
If it's an easy fix that won't cost anything, such as cleaning the sensor, I'll do it myself. If it's not, I'll go back to the garage as this was never an issue prior to them working on it.
2008 1.2 sport
