Abs light on but no fault code showing when machine plugged in, disconnected the battery light went out started driving came back on.
What can cause this fault with no code showing ?
What "machine" are you using to try and read the code...?
Most (inexpensive) handheld machines will only read
engine faults, I'm afraid. You will need a copy of (something like)
multiecuscan (
MES) with the appropriate (ELM/KKL/VAG, etc.) USB-to-OBD cable for your car;
plus the ABS adapter lead (red, I think -- but I haven't had my first coffee of the day, yet... -- but it's worth buying the full set of
three adapter leads, anyway...) to read and reset ABS codes.
I shall ask a moderator to move this to the GP section -- you'll probably get more appropriate responses, that way.
BTW: if none of this makes sense, feel free to ask... -- there are no stupid
questions -- but I, personally, am capable of giving the odd stupid
answer....
