Styling Abarth Bumpers
does the t-jet run ok without the cat, or do u need to sort software out for it to run right with de - cat
The De-cat will run ok , but you will have a FAULT code and a MIL light unless you re fit the lambda in to the pipe work or remove the lambda data from the ECU (The car will not be aware of the lambda)
Regards GCL
if you get an SS turbo you need a completely new manifold aswell. Its not specific to the abarth it will be used on other cars you just need to find out what other cars they are.
