General A few questions
unomad93
Hello, I'm new too this forum so apologies if I've posted in wrong section.
I have a uno 45 fire from 1993.
My heating does not work in the car. I've had the dash out twice to look for a fault but I can't find one. I have heat but no fan to blow it through, so if I use it the heat just sits behind the dash and melts my sound systems wires. As you've noticed it's getting a bit chilly now and I'd like to fix it, does anyone have any advise on where to go with it.
Another question is does anyone know of any after market exhausts that will fit onto my uno. I dont mind welding if I have to but I'd at least want the mounts to be in the same place.
Thanks in advance for any help,
Matt.
Is there anyway I can check the wiring without removing half of the dash again?
There is a resistor on the bottom of the fan-box.
Check if the plug is still connected and without corrosion.
Have you checked fuses jet?
Get a wiring diagram and learn to read it.
Then use a lamp-pen to follow the current until
you find the fault.
