From http://www.puntosports.co.uk/forums/showthread.php?126688-Will-a-6-speed-gearbox-fit
This was about fitting a 6sp mk.2 Punto Sporting box into a mk.1 Sporting, which is just what I'm about to do (along with 1368 bottom end under my retained top end), so maybe I'm on the wrong forum, but you Sei guys know everything.
Answer was: "im sure it would fit the block, but you have different linkages (completely different), different mounting, different clutch, maybe flywheel?, different slave cylinder set up etc"
This sounds harder than expected, if true. Tho in my case it's gonna be a bottom end and matching 6sp box out of a Stilo or Idea, so that makes the clutch etc poss easier than if retaining the mk.1 5sp box. Leaves linkage, mounts, clutch slave to worry about.
Any comments?
Any comments?
