I don't have my trims yet.
Also I don't have the lower channel on my doors as they were heavily corroded and couldn't find a replacement so I went for the N look which will need clips at the bottom.
just for you.....
58 N front door
bottom has 5 holes for short clips
rear edge has no holes but the external tab
front has 2 holes but these are too small for clips so presume screws ... using a slide in plate....
Top has 3 holes for short clips
I'm sure another clip is needed towards the front upper corner..
Problem is fitting the panel would be impossible using lots of Slide in clips..
Now the fly in the ointment....
My NEW N Panels have just 3 holes in the top edge for clips, the two screw holes at the front and none at the bottom, so how do they fit???
(Unless have bloody D panels!! that use the runner...)
I have an old panel that has 5 holes along the bottom and 4 along the top so allowing for the slide in clip in the front corner....
I will see if I can put my hands on the rear panels...
(personally I would f i had the chance have panels made so the holes were cut to take modern plastic trim fasteners....)
Not sure what external trim you have, but those in the know actually recommend the use of the later plastic fasteners rather than the bent wire ones.... The wire ones simply rust and cause the holes to rust too...
