Technical 500 twinair massive water leak
stanley77
My Mrs came home today complaining about an overheating warning. So I filled up the water reservoir only to hear water gushing out the bottom of the engine.
Its a bit tight down there, but I managed a photo, can anybody shed some light on this? The clamp in the foreground seems to have no purpose, unless somebody has helped themselves to bits of the motor.
What exactly is this part that is leaking?
Picture is actually upside down I think,
Agree with some sort of temp sensor, thermostat housing??
A few more images, yes a hose seems to be missing too, but I cannot locate where the other end of the hose would go.
Its upside down so I could get my mobile into the tiny gap!
Lack of schematics and so little space makes it hard to judge what's happened.
Thanks a lot guys, I think the consensus is the thermostat housing.
Anybody got any tips for easy replacement?
Any idea what the missing house could be though, be nice to get it all ordered at once.
Thanks so much for all your answers.:)
Not sure but could be a heater hose.
It's tight in there, have a good look around, maybe spot the said hose
It's hard to believe the hose isn't still there.
But it's easy to believe the thermostat housing has spontaneously self-dismantled itself; this happens on the 1.2 a lot, as some of the parts are made from a type of plastic that degrades when in contact with hot coolant :bang:.
Right now, I'd be more concerned about collateral damage caused by the overheat. How far was it driven with the temperature warning light on?
It looks like the heater pipe stub/connector as blown out of the housing,
look for a rubber pipe with maybe a metal stub sticking out of the end
but as the hose clip is still with the engine the stub maybe gone,
look on line for the thermostat and compare the pic with what you have.
About 7 miles at most. Ill get it off tonight and take a better look.
I cant believe the hose is missing though!
Not too bad a job in the end. Off in 20 mins. Engine cover,battery, hoses removed. You Deffo need a proper hose clip plier. Battery cage can stay.
Bit fidly but you can access the 2 studs.
So metal and plastic. Shoot whoever designed that.
Hose was hidden under battery so must have come off with some force.
Engine seems fine believe it or not.
Thanks guys would never have managed without all of your help
Great work - thanks for posting the pictures.
The 1.2 is the same; it's an appalingly poor choice of materials by the engineer who deigned it.
Some aftermarket thermostats, at least for the 1.2, are all metal; if I were doing this job, I'd try to get one of those if I could.
On the 1.2, if you have the type with the plastic spigot, I'd give serious consideration to routinely changing it at cambelt replacement time.
On the 1.2 also. No need to disconnect any cables; just unclip and swing them out of the way. You only need to take the coolant level below the housing; on the 1.2, the easiest way is to syphon or vacuum it out (if that much is still left!).
You have dodged a bullet there. The 1.2 isn't so forgiving; 15 seconds under power without coolant cover is usually enough to blow the head gasket. On that engine, the HG often fails before the overheat warning light illuminates.
Obviously I'd suggest you keep a close eye on it for a little while, but judging by the quality of what you've posted thus far, I don't really need to say that in your case.
Glad it was pretty simple in the end :)
I am left wondering if its all been apart before..
The crusty white stuff..and RED splodges ..on the hose tail dont look correct :(
Good spot; I'd also thought there was an unusual amount of crud in that hose.
The hose clip is often a giveaway; unless the work has been done by a franchised dealer, I'd expect to see some sort of aftermarket clip if it had been apart before.
