Bluetruck
Inside the car work from the back seat. Pop out the cover in the middle of the cup holder, you'll see a 10mm nut. Remove this and lift out the console. Slacken right back the adjuster and slip out the cable ends. Use a screwdriver and push the outer cables out of their holes. Go under the car and remove the white caps on the rear of the brake back plates. Remove the outer cables from their various brackets. Use a screwdriver and free the outer cable from the backplate. You can now riggle out the inner cable from the lever looking through the hole in the back plate. To refit push the inner cable into the back plate and use a stiff bit of wire to hook the end of the cable into the lever. The rest is a reverse of taking off
