Hi guys,
New owner here.
I bought my new L recently and from the beginning it was always reluctant to start.
When running, it ran OK with no flat spots & revved cleanly.
Then last week it finally gave up and wouldn't start at all.
One look at the distributor made me decide to install a 123 ignition, HT leads, plugs & plug caps. I also got a new battery.
All the above has been installed but still no luck!
One thing that confused me slightly was that the flywheel pulley has no 'notches' as such on the outermost rim but has a cast marker further inboard. This seemed to correspond with the photo in the owners manual. I'm worried my TDC calculations may be out. I did check in the cylinder that the #1 piston was at TDC when this pulley mark aligned with the arrow on the crankcase so thought it must be right.
I installed the 123 distributor as per the instructions - LED coming on, then turning til off etc. I've checked there are sparks: nice robust ones!
I've stripped & cleaned the carb. All keys clean and float valve checked, but still it's a non starter.
I'm at my wits end!
One thing I did notice yesterday was that the starter motor can be activated without the ignition key being turned.......is that normal?
I'm worried that maybe the pulley may be giving me wrong info. Is it possible that it's been fitted wrongly so will give the wrong positioning? I did check #1 pot was at TDC but could it be at TDC in the wrong cycle - is that possible??
The HT leads are connected to the correct plugs.
Anyway....I've run out of ideas!!
Any clues?
Cheers, Hilton
New owner here.
I'm at my wits end!
Any clues?
Cheers, Hilton
