Technical 4X4 exhaust replacement
Where are you based? I know a good exhaust specialist near Stafford and another in Devon who can make up a link pipe. None in-between unfortunately.
Can you cut the pipe under the car, move the front part to the catalyst outlet and joint with flex joint? Then fill in the gap with a straight pipe and exhaust clamps? Or even cut the front end out and fit a longer straight pipe.
forgot to mention that Fiat said they could supply a Manicat..............for £1276
cross referenced to part #...a feckin BH91318H
that part # will haunt me for the rest of my life :(
if you look under all you get one part number for the 4x4 exhaust
if you specifically go into to 4x4 then you get another but the pictures look different
51763719 or 55191581
notice the kink in the long pipe
unless I am doing something wrong
