u33db
Lowered my 1.2 8v daily today to try and correct the silly high ride height.
I went with 40mm "Lo Suspension" springs off ebay and 4 TA-Technix shortened shock absorbers (in yellow!)
Springs were £80 and the the 4 shocks where £122 so a bit of a bargain compared to standard stuff from eurcarparts!
Word of warning about the front shocks though; the thread for the top mount is a different pitch from standard...this means that you cant reuse the topmost bolt above the top hat plate from the standard shocks. Luckily the pitch is the same size as the front shock-to-hub bolts so i had 2 off those lying about from my Corsa i could use instead. Oh, and the passengers side shock is also missing the bracket for the brake sensor cable...unsure if thats model specific??...but no worries as you can just cable tie this wire up somewhere out of the way.
Anyway I got the front shocks, front springs and rear spring fitted today...will do the rear shocks another time to sort my leaking standard ones.
This is how its sitting though...I didn't want it silly low so i think it looks pretty good for 40mm...opinions?
Front may settle a little bit and the back may come up a bit once the new rear shocks go on...handles pretty good now as well..little to no body roll and still a comfortable ride.
