Hi All,
New to the forum as a member but been viewing on occasion.
I have a 2016 Fiat Tipo 1.6d Multijet for about 1 year now.
Car has done 52k and i am getting the dreaded clutch slip, I noticed it a while ago but was only on the motorway in 6th gear when accelerating to overtake, but it seems to be happening in 4th and 5 th gears now as well.
I appreciate that this is common in these cars, but the issue I'm finding is i cant find a garage that is able to do the replacement as they cant find the aftermarket parts from their suppliers.
Having called around 10 - 15 different places only to be told its dealer only as they are not able to source the Clutch kit, flywheel and slave cylinder.
I called Research Nuneaton and they wanted just under £3,000 for parts and labour, it was a good job i was sat down as that more than half the cars value!
So my question is what are you all doing for parts and getting them fitted, out of all the garages i called only one offered to do the job if i supply parts,
Does anyone here have the part numbers for what is needed ?
Where are you sourcing the Clutch parts from ?
Any suggestions on Coventry based or Midlands based garages that can help to fit?
Any guidance or help would be appreciated as i don't want to be in a position where i have no options other than dealer as the clutch has gone totally and its stuck somewhere .
Thank you all in advance.
