Technical 2015 Panda Easy Warning lights :ESC, Hill hold unavailable, engine light - sensor
OK. Si I had this problem for 3 years. My daughters car is 2013 fiat panda lounge. The ESC and other lights would come on for no reason. I changed the battery, went to auto-electrician, tried everything. I read about the brake switch here, and tried that. I took it out, and went to see if I could replace it. It would take several months to get the part. So I put the part I had back in, and no more problems. Everything works beautifully now. It may be magic, or maybe it reset by removing it and reinstalling it. I'm just glad to not have to worry about my daughter's electrics any more.
Thanks to those who accurately mentioned the brake switch as being a problem.
@tiggerwillow :)
thanks varesecrazy
my car seems to be behaving fine at the moment, after she had her battery changed at the garage (i had to have the AA out to her, after a stubborn refusal to start cause she said she is NOT going THAT way, after i had to park her for a few minutes then went back to her and she was like nope i want to go to bed NOW, goodnight
AA came out and jump started her and said there was a problem with her battery not holding power like it should, so she went to the garage the next day and they changed her battery, she been running fine since the battery change, no lights randomly coming on for no reason or anything now
thanks varesecrazy
Modern vehicle control systems sure do like their fullsome volts.....(y)
