My 2015 Ducato 3.0 has a headlight and radio fault. I shall try to descibe it exactly below so you can perhaps help me:
1) No dipped beam, either side
2) No full beam, either side
3) DRLs are working, and when I switch my lights on at the stalk switch, DRLs go off (as I assume they should) and sidelights come on, but no dipped beam. My dash does light up on switching lights on, so I guess it is receiving some sort of signal from the switch?
4) If I pull the stalk for main bean, lights dont work but I do get the blue main bean indicator coming on and off as it should on the dash.
5) Fuses are all good in dashboard section
6) all bulbs are working.
7) Radio etc is completely dead - no lights or anything on ignition being turned on, or when I press and hold the power button
8) The battery was flat when I went to collect the vehicle from the vendor - not sure if there has been some damage done when threy tried to boost it?
I'm guessing these faults are probably connected somehow (but mnaybe not). Thanks in advance for any pointers.
