cinqy boy
A few months ago I changed all the front suspension (shock/links/bottom arms) to get rid of an annoying Knock from the front end. Gradually it came back so back to plan B and I'd thought I'd have a go at the top mounts and anti roll-bar bushes. No way are the bushes at fault (they aint going nowhere) so it was while I was putting the ARB back and had a large bar looking for play. That's when I saw it , the bottom ball joint has come loose in the arm. The bottom arms being pressed steel has the ball joint pressed in the arm on splines.
So will the Cast arms from a mk2 fit the C--p pressed steel mk3 arms.
(No they were not genuine arms but its got a nice pair of Bilsteins to make up for it)
Cheers guys, col
Cheers guys, col
