Panda 2012 FIAT Panda 1.2 Classic Typ 169.
After selling the 2018 Abarth 595 Turismo, this is my new Runabout.
2012 Typ 169 FIAT Panda 1.2 Classic with at the time of the buy 39K on the clock.
Makes sure you have the correct offset or the wheels/tyres will hit "stuff" and you also risk a steering wobble when the wrong offset fights the steering geometry.
Bough another set Bravo wheels instead.
7.0J16" ET31, and they will be wrapped in 205/45R16" tires.
Test run 215/40R16" without any issues, decided to go one size smaller and higher.
Ideal would be 195/45R16", but i don't like 195's on a 7.0J wheel.
The stops are fitted to the inner track rods under the rubber boots. But I doubt you will need them. 100 HP has a six speed gearbox (less space behind the left front wheel). The five speed is likely to be fine. Check your wheel clearance on full lock.
