Hi, I’m new, I have read various threads on Fault codes, I bought a OBD11 meter and the fault is the MAP sensor, can anyone please tell me where it is located, a picture would be a great help?
The cover is held by pipes from the air filter box (which is part of the cover) and rubber pull out socket and pips. It takes a little courage but assuming you notice pipes or stray wires stopping you it can simply be pulled up and off.
Thank you for all your advice, at last I located the MAP censor on the back of the QUBO engine and replaced it, I reset the OBD lights, and touching wood my daughters car is running fine again.
