Technical 2007 Window Wipers/Sprayers not working
I don't think the motor alone can be replaced. Did try taking one apart to repair and somehow ended up with extra parts. The linkage and motor are essentially one unit. A used unit off of eBay should be fine as long as its in decent condition.
Before you buy one, may be worth checking the connector for any corrosion etc. It is under the scuttle and not unusual for water to get there. Could save you a few quid :D
Motor is available separately, as is linkage mechanism.
Some eBay sellers don't know the difference between RHD and LHD mechanisms. They ARE different.
It is possible to dismantle the motor, clean out the hardened old grease, clean up the tracks and reassemble, but usually the symptoms would be slow or erratic operation.
Linkage sometimes disintegrates, resulting in one wiper stopping.
Spindles can partially or completely sieze, sometimes resulting in disintegrated mechanism, or blown fuse, or occasionally dead motor.
Slightly off-topic, I have an intermittent problem on a 100hp at the moment, where the wipers take about 3 minutes to sweep the screen. I have changed the motor (no change), and the mechanism (also no change). Only happens occasionally, but very frustrating. Has dramatically increased my knowledge of Panda wiper systems though...
good point... Ill check this and report back. fingers crossed I can clean a bit of rust off the terminals and get it working again.
@irc
@J4MALD1N
both correct
its hard to test the motor @SB1500 went through some pain and dead ends because the motor worked but the park position wasn't working correctly confusing the body computer
here's a thread where the original poster manged to clean the internal contacts to get it working again
here's the removal procedure
good luck
