Technical 2007 Bravo Throttle body.
CarworldHQ
I have a 2007 Bravo 1.4 with suspected throttle body issues. When fitting a replacement throttle body, is it plug and play or does it have to be programmed in. I would like to scope check the wiring to make sure its not the pedal that is at fault. Where can I get a wiring diagram? Thank you in anticipation.
Tony
Did you test it????????????
you can EASILY test it with MES.
just plot a graph with the accelerator pedal and the throttle potentiometer....should take 10 minutes for a 100% sure test.
You should easily see any problem on the graph, as it massively varying compared to the accelerator pedal.
After replacing, turn the key to accessories, don't start
After about 30 seconds it will start to move and do some position learning, leave it for about 60-90 seconds (wait about 30-40 seconds after it stops moving, then turn the key to OFF...leave it about 1 minute
that should be it.
