Technical  2005 left side brake light
1900ccJtdActiveOwen
Hi there,
I can't find a guide that can tell me how to replace a left side brake light on a 2005, 1.9 jtd active Doblo.
anyone out there that can help me?
Owen,
Just looking in my handbook. It says remove the back speaker cover which I think just pulls inwards. It must be just clipped in. Then remove the upper plastic cap. I think this is on the rear door pillar just above the speaker. Then use the provided screwdriver to undo the light cluster fixing bolt beneath. I should think any screwdriver will do. Then fit the tool provided on the light cluster bolt and undo. Its a bit confusing and looking at the pics in the book it looks to me like you need a 10mm socket or something similar. Also when the tailgate is open there are a couple of fixings on the vertical section below the gas strut mounting.
This is all taken straight from the handbook so let me know how you get on.
Cheers,
Dave.
Thanks demag, very detailed :)
and thank you for referring me to the guide sludgeguts.
Do you guys know what bulb I need for them?
