Panda (Mk3)  2004 Panda Dynamic
Just bought this 2004 Panda Dynamic, 1.2 as a little fixer upper to sell. Having had my 'MyLife' for over a year I have become quite attached to these cars. I'll post updates on this thread of it's little journey.
I've got another Panda, with 64,000 on the clock, I think that's quite the bargain!
I always liked the custard yellow, but I won't be keeping this unfortunately. It requires a bit of loving and once it's got it's fresh mot it'll be going away.
If you're interested, Follow it's journey with me on this
Has it been working since you changed the torque sensor
Nope, I put electrical contact cleaner on the plug insert for the torque sensor and let it sit for 20 minutes before I inserted the plug, and made sure all other connections were in, firmly. Power steering light comes on even on key position 2, without engine on (light is visible, then goes away for a few seconds then can hear the relay and the steering fault light comes back).
If you turn the ignition on
Is the engine check light on
Battery on
Oil on
Immo flash and stay on
Is the clock keeping the time or flashing
On cranking do the oil and battery stay off until the engine fires
What's the battery resting voltage
Battery on
Oil on
Yes, the usual initial light sequence occurs then the steering light comes back and stays on. Same thing happens when engine is on.
I'm at the unit just now doing some tidying up, I will check battery resting voltage but I have already checked Alternator and I've charged this battery up (goes from "charging" to "charged" within 10 minutes.
Right let start at the begining
Check the voltage drop, during cranking
Any other electrics mis behaving, back light of the dash for example
Was on away job hence the delay but, swapped over the steering column, fitted the ignition barrel and clock spring etc, everything all lined up.
We have power steering again!!! - YIPPEE
Ordered a new bumper too as the crack was always a sad part of the car.
Will book this in for it's MOT again!
  • 20251115_162605.mp4
    46.8 MB
  • Like
Reactions: rmjbn1
Doing it's pre-MOT checks today,
Hopefully all goes well on Wednesday!
Usual, noticed the oil weep from the rocker cover gasket but should be here soon!
I believe this little bean will be staying in the Family as unfortunately his Doblo is going to the scrapyard on Wednesday and needs a runabout!
Talk about lucky timing!
  • Like
Reactions: koalar
21 years old
Not bad for 21! Not as well preserved as me (68) but OK!
  • Love
  • Like
Reactions: Adam427 and koalar
PASSED it's MOT on Wednesday 26th with only front tyre advisories.
This little vanilla scoop is now in possession of my Stepfather!
It'll remain in the family as a back-up. I'm so glad the effort and time I've put into this has paid off!
I'll keep updating here about it, and see where it goes!
Thank you everyone who has helped me from saving this from the scrapyard!
- Adam
Hi folks,
My stepdad has been enjoying the Panda buy I believe we've run into a problem,
At the fuel station he says when filling up, the nozzle fills about £0.20 then the gun clicks and this just repeats, which must be quite frustrating. (As in he can't just hold the trigger until the tank is full)
Would this have anything to do with a faulty EVAP purge valve?
Thank you
Adam
