NornIronItalian
- Joined
- Apr 10, 2013
- Messages
- 17
- Points
- 5
Hi
Sorry my 1st post is asking questions, but.....
My Dad's Panda has started hunting, its only been noticed since the weekend. I fitted new HT leads at the weekend, car started and drove fine. I twas yesterday morning my Dad went out to start it before going to work (the battery is draining for some unknown reason and was flat on Monday morning, another thread up shortly) Only thing that has been done has been the HT leads fitted, I done a full service a couple of weeks ago, replaced plugs, oil & air filter and a few other brakes and suspension bits. Dad said he noticed a small misfire so I decided the HT leads could need replaced as they looked old and had gone hard.
When he came home yesterday, he told me about the hunting, its fine when cold, when it comes off fast idle, it drops to 850rpm then a few seconds later revs between 500 - 900rpm, holding a slight throttle to 1000rpm and its fine.
Points to an air leak to me, however I can'f find any leaks using WD40 or see any pipes split or cracked but I can hear a slight hissing near the air con pump.
My question is, are they any common faults on these wee cars, such as manifolds cracking? Any thing else I could have overlooked? I will probably have to start stripping the car at the weekend to see what I could find, but it would be handy to know a few common faults to point me in a direction. No engine light on and no other symptoms.
Thanks in advance
Andy
Thanks in advance
Andy
