hymerfiat
Hello from Greece!
Made it all the way here from Derbyshire in our Ducato-based camper - 2002 2.8 jtd. But have been having some issues for a couple of weeks, starting in southern Italy, now getting worse:
About two or three weeks ago, we had a few short episodes of loss of power (or possibly limp mode?? not sure how to tell the difference?). Essentially little/no response from accelerator, and lurching somewhat when changing gear. You can slowly get up to a reasonable speed (e.g. 50 mph). No pattern to it, and varying from a slight blip to a few minutes long, interspersed with longish periods of no trouble. You seem to be able to accelerate out of it to some extent... in other words, if you give the van a bit of welly in a low gear, it seems to splutter for a second and then the problem stops.
We found a garage who hooked us up to the Fiat diagnostic plug (we're pre-OBD), and we got the following errors: P0220, P1555 and P0235.
However, the problem didn't occur at the garage and in fact seemed to just go away - and so we carried on another 1000km, well into Greece (now in Corinth/Athens area). But a few days ago, back to the same intermittent loss of power. Went to a local place who straight off changed the fuel filter and put an additive in the tank. This did seem to make a difference, but then later that day we had the same occasional blip of loss of power. Then the next morning, loss of power non-stop for about 20 mins. Went back to garage, who changed the brake pedal sensor (presumably related to fault code P1555, and you could easily see that the press-in valve thingy on the sensor was faulty). They also cleaned and reseated the fuel injector connections, cleaned the ECU connections, etc.
Annoyingly the problem never happened at the garage, despite many hours there!
Anyway, later the same day, short and intermittent loss of power/limp mode again! Argh.
Any ideas on what we can try? I've read elsewhere on this forum about throttle sensor issues (which I guess could be related to P0220?). And what about P0235?
Another consistent grumble from the mechanics we've heard both in southern Italy and Greece is about bad fuel / cheap diesel.
Any ideas what we can try next? And are we damaging the van by continuing to travel?
Thanks in advance!
Thanks in advance!
