Hi guys, Just bought a 2000 Bravo, 1.6 16v Trofeo from a work collegue...
Hes owned it for 8 years, full service history, 47k miles, absolutly mint, never drove above 30mph and still smells like new inside!
Was running fine for the 15mile trip home then myself and the gf cleaned it inside and out, i then jet washed/degreased the engine (with it running) fine...went out to the shops...then the problem started!
No power...sounds like its missing/stuttering "d d d d d d d r r r m m m m" instead of a smooth "drmmmmmm" when revving...struggled to get up even slight hills.
Poss sounds like its running on 2/3 cylindors...
Took it back home, cleaned the throttle body out, put new plugs in it, new air filter and bought new ignition leads...Also put high octane fuel in it and a tub of injector cleaner.. (as the injector light came on for a little while)
Still didn't run right but it was ALOT better...then after 2mins of revving it, it was fine again!! And injector light went off and has stayed off..
Took it out for a spin and it ran perfect!
The day after started it up, its running like a bag of spanners again...
Took it out and its got hardly any power again (better than before but still stutters)...then all of a sudden all power is back and its running fine....then it will start to run like a bag of spanners again...ARGHHH!!!!
Any ideas guys???!! Iv read that coil packs are a common failure...could this have failed because of the engine wash?
I know italian cars are prone to problems with water but I tried to keep away from the electrics...
I want to plug it in the diagnostics to check for faults, any ideas where the diagnostics port is? Iv heard its a 3 pin under the bonnet somewhere?
:bang:
:bang:
