Seicento 2000 899 Seicento SX
Hi all, this is my new Seicento which I picked up today, I'm well known in the Panda 2012+ section of the forum, but that car was recently giving me a constant headache with multiple issues so got rid & decided to go old school with this little beauty being the result, I've had a Cinquecento in the past so sort of knew what to expect😂 this is a 2000 pre facelift SX with 22k which cost me just short of £2k, all the underside is solid with no holes anywhere just a few surface bits which I've started to clean up beginning with the worst surface area being the back of the boot floor & bumper brackets which have now been wire brushed & treated so just a couple more dots to do & then rust proof the entire underside to future proof her, anyway here she is
IMG_20240620_180440_084.jpgIMG_20240620_180449_816.jpgIMG_20240620_180509_254.jpgIMG_20240620_180521_563.jpgIMG_20240620_180534_120.jpgIMG_20240620_180622_273.jpgIMG_20240620_180651_617.jpgIMG_20240620_180742_955.jpgIMG_20240620_180842_567.jpg
Some nice cars in your photos and yours is looking very tidy. I bought a "performance" eprom from some chap in Portugal. Put swapped it over with the standard eprom from a spare ECU box I had. Installed it, but my car wouldn't start, even though the performance chip bypassed the imobiliser.
Took it back out and went back to the original ECU. Only to be told by a friend you have to keep on trying and trying with the start up and eventually it'll kick in. Maybe i will try it again someday?
You thought about trying to find an Abarth body kit for your Seicento?
When I first installed the box it did seem a little flat like a flat spot on a carburettor so I adjusted it slightly as it has an adjustment screw which is limited to 25 turns in each direction, I think it might have been to do with having an aftermarket air filter already installed so after slight adjustment it now feels spot on. With this particular box & being an 899 the existing ECU stays in place, the box comes with 2 wires with quick splice connectors on the ends which connect to the 2 wires for the air intake sensor so the connectors only pierces the insulation for the wire without cutting the actual wire so if I change my mind further down the line it's reversible as the wire isn't cut I'd just have to put a little insulation on each one which is quick & easy. I personally think they look better without the Abarth body kit, also behind those skirts would be heaven for rot 😂
From memory I think these little tuning boxes are basically a variable resistor, there may be more complicated ones out there though I'm not sure.
The splice into the air temp sensor is (likely) spoofing its value so the ECU thinks the incoming air is colder (and therefore more dense) making it richen the mixture. I could be wrong about your specific box but this was how a lot of them worked back in the day
That seems like how this one works, I think this coupled with my BMC filter & Sporting exhaust is more or less the equivalent of a stage 1 remap, it seems to have worked though as she does seem to have a better throttle response & a little more torque in low to mid range revs, it said 15% which is probably exaggerating a bit 😂 but there's definitely an improvement especially on motorways, I wasn't too sure at first because I've never had one as I'm usually pretty old school & the reviews on these tuning boxes tend to be a bit hit & miss so I thought for £70 I'll try it & if it doesn't work there's a 30 day guarantee that if you change your mind after installation you get a full refund but so far I'm quite happy with the result. The 899 engine isn't staying in it forever as in say the next couple of years I'm looking to convert it to a 1.4 FIRE engine possibly from either a Punto or Panda 100HP but I need to look into it a bit more 😂
Even a 1.2 8v from a mk1 Punto is a decent upgrade for a cento and they need bugger all to run, much simpler than a late 1.4 16v, depends how much of a project you want to take on!
I was thinking a 1.2 8v from a MK1 Punto SPI as the wiring is virtually the same apart from oil & temperature switches which I heard need extending but there's not many left, I'll keep an eye out & see what comes up but I cannot purchase one at the moment as I have nowhere to put an engine 😂 or if a scrap car comes up with a decent engine that might be a way to go, for now I'll stick with the old 899 but that is the eventual plan when funds & time allow 😂
So today I decided to do the oil & filter change as I'd done 5,000 miles since the last service & also for some reason there was a very minor seep from the seal on the filter so the seal must have been defective perhaps although I couldn't see anything obvious on removal so mechanically she's all ready for show season, I also decided to change the fuel filter as the last couple of days she's had a little trouble starting whilst also slightly stuttering & was a little noisy & to say it was a nightmare is an understatement 😂 so she still had the original 25 year old filter dated August 2000 so it was well overdue but someone had been in there before me trying to remove it resulting in rounding both bolts so I had to cut the plastic bracket that's part of the filter around the bolts so that I could get some mole grips on them to get them out which resulted in the heads snapping 😂 so what's meant to be a 5-10 minute job took a lot longer & at some stage the remains of the bolts need drilling out but for now as I need the car it's temporarily cable tied in position until I get round to drilling the bolts out but the cable ties are secure enough for the time being, started her up & she's back to her usual great running self with no misfire or stuttering
I picked up a genuine old stock fuel filter the other week, so will get it swapped over on the next service. Cam cover gasket is leaking again - two in about 5000 miles. Bought a genuine Fiat one this time.
I got a Febi Bilstein one of eBay as their stuff is usually quite decent, I think they were about £7 or £8 each, my rocker cover gasket was also Febi & it's still dry after around 6,000 miles. I try to use genuine parts where I can find them though as a good example of this is I bought a 899 breather hose on eBay last year for around £35, I can't remember the brand but it fell apart within 6 months so I bought a genuine Fiat one from Ricambio for about £60 as I thought I can't be bothered to keep changing them every 4 - 6 months 😂
So after changing the fuel filter the pump decides to start making the same high pitch noise that the old did last year, so I thought the pump can't be knackered after a year & also it's a genuine Fiat part so I removed the pump & the crud around the connector & in the bottom of the pump was quite a bit of muck so I held it upside down & dosed everywhere on it with WD40 & watches all the crud come out, fingers crossed after putting it back in it appears to be nice & quiet again 😂 I did have 1 stud casualty though with one of the 8 studs which holds the retaining ring to the tank but apart from that it's all sealed up good with no leaks so for now she's all good, upon closer inspection of the outside of the tank though I think I'll be replacing it within the next year as it's starting to look suspiciously crispy around the edges & seams so I'm not too concerned about 1 snapped stud 😂
Do cento's not use plastic tanks then? Seems a bit absurd when Fiat started using a plastic tank on the Panda (2WD ones anyway) in 1986
The plastic tanks on the Panda's were a brilliant thing but for some reason Fiat decided to do a backward step & reinstate steel tanks for the Cento's where they had a massive recall which I think if I'm not mistaken went on for around a decade
Learn something new everyday, what a odd decision!
The previous owner of my car got the fuel tank replaced. I think it's on its third one, as it would've had one replaced under a recall back in the day.
I'm not too sure if mines had one or not, I assume it would have had one as part of the recall but it's looking a bit scabby around the seams, I've had to order a new pump now since running out of fuel a few days ago & changing the fuel filter as it's not been happy since & the noise coming from the pump is horrendous 😂, it's pretty bad though that a genuine Fiat pump has only lasted a year as it was the first thing I changed on the car a few days into ownership so I got a Bosch one off eBay from a reputable motor factors that I've bought many parts from with a discount code for £67 with free delivery
Check via the DVLA website to see if your car has any outstanding recalls - You just need to enter in your car's Registration number. I imagine the fuel pump sucked in twenty odd years of grot from the bottom of your fuel tank! Maybe time to replace the tank as well?
I've checked the DVLA site & there's no outstanding recalls against my registration number so I can only assume it must of been done at some stage in the cars life, the inside of the tank looks quite clean still as it did last year when I replaced the pump then & also I've used a petrol system cleaner every time I've filled up since, the outside of the tank looks a bit scabby but nothing to be concerned about yet as there's no leaks etc, for now I'll put in a new pump as she's starting on the button & running fine apart from when the pump starts screaming at me within a short distance & if you stop & turn the ignition back on the pump is struggling to prime, I'm wondering if it's because the pump was NOS so had been sat around for many years & probably been knocked about in storage etc, from memory the date on the box was like 1998 so had been sat around for 26 years & it was a bit dusty when I got it out of the box so maybe it was exposed to the elements at some stage which probably hasn't helped, for now just to get her driving again I'll change the pump as it was quite reasonable cost & also I'm not too sure I wish to be dealing with rusty tank bolts at the moment 😂 but I'll keep a close eye on it as I am looking to replace the tank at some stage perhaps end of summer/autumn time when the show season is over with as I've looked to see how much they are, there's a seller on eBay selling them with new seals & nuts etc for £93 so that'll be the route I go down but for now just a pump to get her usable
So new fuel pump arrived this morning nice & early so got it all fitted up & went for a 26 mile drive, all seems good & she's back to her usual self very revvy & eager to go 😂 & the tick over seems a bit smoother as well, I've decided I'm going to enjoy her as she more or less is for the next year or two & then she will be converted to a 1.2 8v FIRE engine (preferably SPI but MPI will do if not even though it's slightly more work but doable) from most probably a Punto with a Seicento Sporting gearbox, I was looking into a T-Jet from a 595 Abarth but that seems like quite a lot of work which I frankly can't be asked with 😂 also I found out recently they are dual mass which puts me off a bit as I'm not keen on dual mass flywheels so a 1.2 8v FIRE it shall be with Sporting box when the time comes but for now I'll enjoy the 899 in all it's glory 😂
Keep the 899 and try do a Cinquecento Trofeo conversion??
