Technical 2.8idtd injection pump priming
Torq
Athlone and Dublin.
Hi All,
long time no see! A couple of years ago a valve snapped in my camper van writing off the engine. I've finally got around to rebuilding it and all is good except I just can't prime the injection pump. I've fuel going to it but nothing is coming out the pump nozzles that feed the injector pipes.
I can hear the pump solenoid clicking when I turn the ignition on and the pump was working perfectly before the tear down 6mths ago, it was so good it would run happily on 3 cylinders with a valve head bet into piston no1.
I'm at a loss. Any suggestions?
Torq
2000 2.8idtd. mechanical injection, pre common rail. No lift pump in the tank
The only bleed screw I can identify is part no 31 in this diagram
This a rare time when the internet has not come to the rescue!
Thanks.
T
