Technical 2.8 JTD Timing Belt Replacement
Sunshine Coast Qld, Aust
Have received a few requests for the guide I wrote out for myself next time I need to do this job so here it is -
I have included a link to some pictures but these are not in order or that good because of the limited visibility & accessability on the Ducato. Hopefully my step by step guide will have sufficent info to make up for the lack of step by step pictures.
Timing Belt Replacement Ducato 2.8 JTD 2003
Here is my step by step guide & what I encounted in changing the timing belt on a 2003 Ducato 2.8 JTD fitted with A/C.
As this is a JTD Common Rail Electronic Injection there is no injection pump timing to set (thank heaven). With the 2.8TD it would necessitate the upper timing cover & associated parts removal to enable enough room for timing of the Injection pump.
1. Disconnect the battery, remove front engine cover by undoing the 4 retaining clips.
2. Remove engine top cover , which necessitates the removal of part of the engine lift bracket retaining the 4 electrical cables for the injectors at the bottom right corner as the top cover has a projection under the wiring so cannot be removed until the part of the bracket is moved out of the way. I also removed the bracket bolted to the intake manifold behind the cover as it has some wiring harness retaining clips & two studs with nothing attached to either which hinders easy removal otherwise.
NB: On reinstallation of this bracket I bent the mounting lugs (& removed the studs) so that the two large plastic wiring loom clips could be used to support the coolant bypass pipe that crosses over from the thermostat housing to the front of the engine. This was done because I had asked the parts department at the local Fiat dealer what was the most common thing that went wrong with the 244 Ducato. Apparently out here, it is this pipe cracking from the vibration - which it certainly does, I was told it was $400!! to replace. Think I would use a rubber hose instead for that money.
NB: It is not possible to remove the top timing cover unless the RH (front) engine mount is removed but it is apparently still possible to remove & install the belt regardless even with A/C fitted, this is the method I used but it would be much easier with the engine mount removed especially with A/C fitted. Now as I was doing this alone I needed to have some way of locking the flywheel while I loosened the crankshaft bolt & lock crank during belt removal/installation so I removed the starter motor & made a locking tool anchored with 2 of the starter bolts which worked well. It consisted of a piece of flat steel with a projection welded in the centre to engage with the ring gear on the flywheel – see pic.
3. Remove the bolts for the A/C pipe bracket, bolts for the top timing cover (2 topside, 1 under) & remove the bolts for the Power steering reservoir & move to one side DO NOT DISCONNECT THE HOSES.
4. Then rotate (in the direction of engine rotation) the crankshaft (will need a 36mm socket) & line up the timing marks on the camshaft with the one on the cylinder head under the camshaft position sensor. You cannot see the crankshaft sprocket marks to line them up until the crank bolt is loosened & the pulley removed as the pulley has no timing marks & it is not located in a fixed position on the crankshaft.
5. Loosen the bolts for the A/C tensioner, the pivot bolt for this is 15mm (not a common socket size in my sets) & adjusting bolt & remove the belt marking the direction of rotation on the belt, then loosen the 3 bolts for the alternator adjustor (accessed from underneath with a 13mm &12mm socket & extension bars & from the wheelwell using 13mm spanner above the drive shaft) & then remove the alternator belt again marking the direction of rotation on the belt.
6. Then loosen the 36mm crankshaft bolt (normal RH thread) with the flywheel locked using whatever method - be careful not to drop the pulley (it is pretty heavy) when the bolt is removed as it only sits in a small recess on the crankshaft with a thin spacer between it & the crank & can easily fall off.
You can now see whether the timing marks line up. There seems to be confusion with the timing marks as the Autodata specs I have states “ensure crankshaft sprocket dowel pin aligned with projection on timing belt lower cover (9)”. As there are 2 marks on the sprocket - the keyway & a “Dot” directly opposite. From information from the local Fiat dealer it is the “Dot” that is the mark not the keyway (dowel pin?). The “Dot” is what always lines up anyway, after numerous rotations of the crankshaft. If you get a genuine replacement belt it has the direction of rotation & 2 white lines marked on it to line the two timing marks up to as it is installed (whether the aftermarket belts are the same I don’t know). I would also mark the original belt before removal for comparison with the new one or in case the replacement belt has no markings.
7. Remove the Tensioner nut (17mm), the lower timing cover bolts 10 mm (3) & then the lower cover. Loosen the tensioner bolt (13mm) which is behind the lower cover & lever the tensioner pulley away from the belt, (it doesn’t move very far as can be seen in the pic) retain the tensioner in position with an adjustable wrench or improvise or use the proper tensioner locking tool if available & then remove the timing belt. I used a small pair of vice grips - in the photo of the tensioner assembly which is actually installed into the bottom of the water pump, when pushing the bracket that the tension pulley is attached to back, the small ‘T” (about the size of a 10 cent piece) on the left is where the “Tool” is installed to hold the spring tension off the tension pulley while removing/refitting the belt.
NB: Now with air conditioning installed this process is easier with two people as it is difficult to get the old belt off through & around the protruding pump pulley bolts & the cover projections & in retrospect it is probably easier to remove the engine mount so the cover can be removed & also easier if the A/C pipe is disconnected from the compressor necessitating regasing but it is the engine mount & top timing cover that are the main problem. The same applies to installing the new belt although much easier than removal – a two person job as well.
8. Fit the new pulleys which really is compulsory when installing a new belt (on close examination I could not see anything wrong with the old belt or the two pulley bearings @ 43K & 6 years) & tighten the idler pulley bolt (15mm) to specified torque.
9. Ensure the timing marks are still lined up, you need to temporarily install the lower cover again (if flywheel is locked I would think it is not really necessary as it cannot move) & recheck that the camshaft marks line up, fit the new belt starting at the crank, installing anticlockwise to pump, idler pulley & then the cam sprocket, tensioner pulley & back to crankshaft (if using a genuine belt the 2 white lines on the belt should line up with the 2 timing marks when installed correctly, if it is 4 teeth out on the camshaft sprocket the belt needs to be rotated 180 degrees in regard to the white lines).
Install the lower timing cover & bolts (3) & tensioner nut then the crankshaft pulley & bolt (hand tighten) Remove tensioner locking tool or “adjustable wrench tool”.
Slowly turn the crankshaft two turns in direction of rotation & remove crankshaft pulley bolt & pulley, ensure the two timing marks (the “dot “on the crankshaft) & camshaft still line up (the two white lines on the belt won’t line up again) tighten the tensioner bolt (25 Nm) which needs to be done before installing the lower cover & its bolts & tensioner nut (37-47Nm) Reinstall crank pulley & bolt. Lock the flywheel & tighten the crankshaft bolt to 200 Nm. I did do a half a dozen manual rotations to ensure that there were no lockups with the valves hitting the pistons!
Another problem I encountered was once the belt was on past all the projections etc I put the new top idler pulley on first but it was then “very difficult” to get the tension pulley on with the limited space & limited access & slackness in the new belt under the vehicle so I took the idler off & got the tension pulley on first & then again with some difficulty the top idler pulley second. I had the same problem with both pulleys in that with it pressed against the new belt it binded against the belt, which made it hard to slide the new pulley on to the very close fit on the bearing anchor. I used a” very thin” layer of water based lubricant on the part of the pulley in contact with the belt which did the trick & then wiped it off immediately. So maybe the pulleys should be installed first, and then the belt is installed down through the cover as it would be if not replacing the pulleys, although you would probably still have the same problem?
NB: The lower tensioner pulley has ½ width anchor & 2 “washers” the internal one has a ridge which fits in the inner bearing hole (same diameter as the anchor) & will need something sticky to retain it in place (I used a small amount of silastic) while the thicker washer with stud sized hole is also installed next over the tensioner pulley stud to keep it in place (as well as the bottom Timing cover) & the flat/spring washer & nut are then installed & tightened, this arrangement may have something to do with easier installation of the belt?.
10. Reinstall main components to enable the engine to start & run in the reverse order of removal & start the engine. If everything is OK then complete the reinstallation of all remaining components, top engine cover, brackets, underside engine guard etc
I purchased the genuine parts (Belt & pulleys) for the 2.8 JTD Iveco Turbo Daily, as in out here in Oz they are 30%-40% cheaper than buying the Fiat ones from the same dealer & a couple of the part numbers are even the same.
NB: As this is an interference engine if you are not sure what you are doing, & are not comfortable with doing it yourself get a qualified Mechanic/Garage to do it as if it is not installed correctly it will be very expensive to fix the damage! But this guide might give those of you with sufficent expertise to give it a go yourselves.
NB: I take no responsibility for any damage resulting from using this guide - use it at your own risk.
Here is the link to the photos
http://s790.photobucket.com/albums/yy189/fspirit/
Thanks for very detailed guide for belt replacement for Ducato 2.8 JTD. I have just replaced the timing belt on my 2003 campervan with 35K miles using your guide which I found very helpfull. I found it much easier to remove the front engine mount to remove the front cover - this made working on the belt and rollers much easier. Just a note to say be aware the rollers are slightly different diameters - the smaller roller fits on the tensioner. I got slightly confused when I did it as I could not remember which one went where. The van has now done 500 miles and is runnig well.
Thanks again for this well writen guide.
Excellent work, Freespirit :worship:. Would be even better to copy the post to the Guides section so it is easily found later on. (y)
Thanks FreeSpirit for Timing Belt info. My Alternator Drive Belt has just broken and wound itself round the drive pully damaging the timing belt. I will use your guide to do the job myself. The Air Con tensioning pully is also damaged. The MD wants 120 Euros for a new one. Can anybody tell me if this is a Joke. Regards Sneem.
Moderators note.
Freespirit, this should be in the guides section (which I will do) however were not allowed offsite picture hosting...but its a useful guide so i'll overlook it;)
Can you add the pictures to your FF gallery or would you like me to do it?
Is it just the pulley itself or the tensioner assembly as well, I would think that any good auto parts store would be able to supply a A/C replacement tensioner pulley. These would be an aftermarket brand (Gates or Dayco to name two) & would not cost 120 euros more like 10. The A/C tensioner pulley went on our previous motorhome quite a few years ago & I got a replacement one from Repco - an National auto parts place out here for $12.
Cheers (y)
Moderators note.
Hi T14086
I put a copy of the 2.8JTD Timing belt Replacement post up in the Miscellaneous Guides guides section 6 months ago as there doesn't seem to be a Ducato section listed there ? If you like you can add the pictures to the FF gallery if it is not too much trouble & also to the guides section as well as I am not sure how to do it & don't think I have the permissions to add that many pictures so it may be better if you did it?
Cheers
is a 2.8jtd the same as a 2.3jtd in regards to doing a timing belt?
The 2.3 is a completely different engine & a different method of timing the belt system as I said in a previous post it would be very wise to download the elearn workshop manual from the the downloads section & burn the ISO image to CD. The 2.3 needs a set of locating pins to line up the the two camshafts & also some method of holding the camshaft sprocket whilst undoing the the retaining nut & also locating pins for it (the camshaft sprocket) as well as the crankshaft whilst fitting the new belt! So all I can suggest again is to download the eLearn Manual which gives a explanation with diagrams of how to do it. The proper tools are necessary but these can improvised to carry it out - as I said hofsi did his with improvised locating pins/tools.
To put it simply it is a more complicated timing system than the 2.8 engine so would be very hard without the procedure listed in the eLearn manual.
If after you have downloaded the eLearn RAR file with the ISO in it, you don't know how to extract & burn the ISO to a CD etc as explained in a previous post I would ask someone who does to help you.
Cheers
Hi T14086
Cheers
(y)
My belt is due for replacement, thanks for posting your guide, it will be a big help and also save me a few quid! (y)
This was very useful - thanks for putting it up. I also have the Fiat manual on CD but I think I would have struggled just using the Fiat guide....
I changed the cambelt today on my 2004 2.8JTD which had 55km on the clock.. I got a genuine Fiat belt and tensioner kit, I wasn't sure that I'd need the tensioners as I was changing the belt more for age related reasons than mileage but I'm glad I did. The belt itself looked fine but the tensioners had slightly pitted surfaces and looked worn although the bearings themselves were fine. So, I would definitely recommend belt + tensioners especially as it takes a few hours to do the job..
I put my vehicle on solid wood ramps so I could get underneath, the hardest job was getting at the alternator adjuster locking bolt, there was no hole in my offside wheel arch so I had to thread my arm up through the driveshaft area and could only get about a 12th turn on the bolt which needed a lot of slackening... There was a hole in the bellhousing a bit above and a bit to the right of the starter motor which took a 8mm approx bolt - this could be used to lock the flywheel at the timing mark.
My vehicle has air conditioning but I removed the clamp bracket by the battery tray for the aircon pipework and used a very strong cable tie to get the pipes out of the way, I did the same with one of the main coolant hoses to get enough room to work. I was able to remove the old cam belt and fit the new one without taking off the offside engine mount or the main cambelt cover but it is fiddly and you have to be careful not to damage or kink the new belt. When I next do the job I'll have the aircon drained professionally beforehand so I can remove the main aircon pipe (this is what the Fiat manual recommends)
With the flywheel locked and the cam in the right position the two white lines on the new belt are easy to align but you need to double check when fitting the lower tensioner pulley that the belt hasn't moved round a tooth as the crankshaft drive pulley is quite small and the belt quite stiff causing it to lift off easily until the tensioner pulley is on.
I hand turned the engine 4 or 5 times double checking the timing marks lined up ok which they did but it is still a slightly anxious moment when you fire up the engine - high stakes if you get it wrong...!
The job took about 6 to 7 hours but I did take my time and double check everything etc...
Good luck !
this is some excellent information and many thanks. i will 'have a look' at my belt with a view to changing it. But being the cynic I am when you buy a cambelt does it have a sell by date stamped on it. In other words my vehicle is 2005 and done 4,000 miles at which point i would question changing it at all. It would certainly be an age factor as wear hasnt really come in to it.
How do i know what date the belt was actually manufactured prior to it being fitted to my engine on manutacture and assembly (i.e. was it on a shelf for 6 months?). Is it to be changed 5 years from the date i purchase and drive it off the forecourt or 5 years from the engine number issue?
its a dead cert that people will change them as advised as the fear factor of engine failure is very high but I just question some of the logic behind it all.
This is a great explanation and helped when I was changing the cam belt. I do have one concern; I had initially thought that the tensioning device would always exert a tensioning force onto the belt via the roller and compensate for the belt stretching and flexing. However it seems that what it actually does is set up the tension on the belt when it is first installed. I say this because when I tighten the tension roller central mounting bolt the roller is locked in this position an the tensioner has no further control. Is this correct or have I done something wrong?
Thanks.
Damm good write up free spirit...and that coming form someone in the trade
The only thing I would do different & to make the whole job so much easier ...especially for our "non trade contingent" is to remove the O/S enging mounting...in the scheme of what's being done its only another seven bolts/nuts to remove along with supporting the lump. This make the whole job so much easier.
Hi Nayazindagi
RE your post, yes the tensioner is only there to get the correct belt tension on the initial Belt installation when turning the engine over two revolutions manually after fitting the new belt, then torqueing the bolts.
After that, I suppose the same procedure again could be done at some point during the life of that particular belt etc. But as there is no recommendation of this in the WSM, but at that stage it would be better to install a new Timing Kit - Belt & Roller pulleys at the recommended intervals
Thanks for the compliment on the write-up Olympus & yes I agree removing the engine mount would make it easier. (y)
Cheers
Thanks for the write up. I,m doing the job now, will probably take me all weekend, and I,m no stranger to mechanicals. I am changing the water pump as well. which makes this a much harder job. The water pump pulley has to come off, to access some of the fixings, a bugger of a job, plus some of the fixing bolts hold the alternator assembly in place.!
The water pump replacement also involves removing the engine mount, so doing the actual belt is easier.
Here are some extra tips;
1) the higher you can get the drivers front corner off the ground safely, the easier it'll be.
2) Make sure you have a 15mm spanner and sockets, you'll need them!
3) Drain water into a bucket (easier because the motor is off the ground) antifreeze is expensive.
4) If you look from the front of the engine, down to just right of the starter motor, on the bellhousing, you will see a 5mm'ish hole. Get a bolt, that just fits it width ways, and goes down it with 10mm sticking out. If you remove the starter motor, you will see that this bolt has come right through, and , with a little move of the crank pulley, will sit in a recess in the flywheel, thereby locking the engine. All this can be seen once the starter motor is out.
5) If you buy a Gates kit (belt, two pulleys and a tensioner) there are instructions for doing the job, along with torque settings, in the kit.
6) Borrow a torque wrench....or buy one, you'll need it.
7) change the alternator belt as well, its not a job you want to do beside the road in the rain, keep the one you take off as a spare.
For anyone who think doing the water pump as well is overkill....although the two pulley bearings were OK, the surfaces were pitted, but the water pump had definite play in the shaft......better now thatn later methinks.
I'm in the process of doing the timing belt on my 2.8 JTD powered MH. The new belt's back on and everything lines up. I'm reading Freespirit's guide and I'm a wee bit confused by something near the end of paragraph 9. Quote "tighten the tensioner bolt (25 Nm) which needs to be done before installing the lower cover & its bolts " Can anyone shed on which bolt this is ?
I'm just about to reinstall the lower cover and crank pulley to do some test rotations of the engine by hand. All going well my intention was to realign the marks, tighten the tensioner nut and the crank pulley bolt. I can't see anything else that requires torquing before I put the lower cover back on.
Thanks in advance for any replies and to Freespirit for producing this guide
Dave G, Scotland.
