FiatTechSam
- Joined
- Aug 4, 2015
- Messages
- 41
- Points
- 11
Sure do a leak off test but low pressure isn't going to cause a canbus error, the cutting out coincides with the canbus error, and theres a good chance in fixing that error you'll find loom damage, water ingress, corrosion etc.
If the injectors were leaking badly enough to triggering limp mode under heavy load you'd usually have something like p0089 or p0191 though not guaranteed. Plot of requested vs actual pressure and regulator % would verify it.
I am a technician at a fiat main dealer, the fault codes p0087 CAN cause a can line fault, I've done 100s of ducato's like this, it's a common problem on them. When the engine light illuminates it looses power and brings on the abs light and esp light, when you check the error codes you will have p0089 and the can fault to the abs ecu, this happens because it temporary shuts down the abs ecu, creating a can fault
