Technical 2.2 ducato (ford) engine injectors codes?
Gehngus
Wales
Hi Guys.
I have Mes now and will log ot on the map.
Im in N Wales.
Question I have is about the injector numbers.
Very hard to read. Especially the one printed on the weld.
Noticed oil on one so took it out and changed seal. Tried to read it while out. Not much better.
These were the originals gone back in the wrong way around.
Which numbers are the actual code?
Or. Can I get the already programed in numbers as these are the same, but in wrong cylinders?
As you can see. Some numbers are not good and may be wrong.
Many thanks.
Model
Multijet 100
2010
Ok I found them, so entered values.
Runs worse than ever. Stalling now. Once was perfect.
So I have to ask. Are the cylinders numbered 1 to 4 from left to right?
Also. When asking for a pilot learn which is esential i think, Inget "failed to execute"
Many thanks
Don't if any help but my 2010 Scudo 2.0 litre has the Peugeot engine which I believe is similar to yours and No1 is at gearbox end.
Out of curiosity what Diagnostics are you using, most on Forum use MES but that Scudo having the Peugeot engine wasn't on the list so I had to get MAXIECU tool.
Yes it is the puma engine. I have the same engine in my ford transit.
Re the injector codes, when I tried to look at mine on the RHR Peugeot 2.0 litre Engine in my Fiat Scudo after helping code some on a 1.3 Panda MJ using MAXUECU scan tool it appears to do it automatically without entering the codes.
This was fortunate as they are barely readable in situ, even when using an endoscope camera:)
